Einleitung
Use this guide to replace a cracked or malfunctioning screen on your RCA Apollo 8 tablet (identified with model number RCT6573W23).
Was du brauchst
Insert an iFixit opening tool into the gap between the tablet and back panel.
Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
Release the gold and black tab from the battery that's attached to a gray wire. The gold tab is held down by an adhesive; pull it until the adhesive releases.
Remove the yellow tape that is around the battery.
Unlock the ZIF socket and detach the display data interconnect cable from the front panel assembly.
Remove the screw from the bottom left of the tablet.
Place an opening tool under the screen.
Pry up the screen and it will unclip from the clips holding the screen down.
