Einleitung
This guide will instruct you to replace the effect button circuit board on the RCA CC310.
Was du brauchst
Remove the six 7.9mm Phillips #0 screws on the back and bottom.
Remove the one 3.8mm Phillips #0 screw on the bottom.
Remove the two 7.5mm Phillips #0 screws on the back and bottom.
Remove 5.8mm Phillips #1 screw from the side button panel.
Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
Pull the left panel away from the rest of the camcorder.
Unplug the red speaker cable located at the rear of the device.
Unplug the two cables on the bottom of the effect button circuit board.
Unplug the cable at the top left side of the motherboard.
Pull the plastic tabs away from the circuit board.
Pull the board away from the camcorder.
Use a spudger to help push the mini-circuit board away from the camcorder at the same time.
Unplug the cable in the middle of the effects board.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
