Zum Hauptinhalt wechseln
RCA CC310 Main Motherboard Replacement
Was du brauchst
  1. RCA CC310 Main Motherboard Replacement, Disassembling RCA CC310 Left Cover: Schritt 1, Bild 1 von 2 RCA CC310 Main Motherboard Replacement, Disassembling RCA CC310 Left Cover: Schritt 1, Bild 2 von 2
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
  2. RCA CC310 Main Motherboard Replacement: Schritt 2, Bild 1 von 2 RCA CC310 Main Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
  3. RCA CC310 Main Motherboard Replacement: Schritt 3, Bild 1 von 2 RCA CC310 Main Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Pry along the seam on the top side near the buttons with a spudger.
  4. RCA CC310 Main Motherboard Replacement: Schritt 4, Bild 1 von 2 RCA CC310 Main Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
  5. RCA CC310 Main Motherboard Replacement, Main Motherboard: Schritt 5, Bild 1 von 2 RCA CC310 Main Motherboard Replacement, Main Motherboard: Schritt 5, Bild 2 von 2
    • Pull back the plastic tabs along the edges of the motherboard.
    • Disconnect all the cables along the left side of the motherboard.
  6. RCA CC310 Main Motherboard Replacement: Schritt 6, Bild 1 von 2 RCA CC310 Main Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Disconnect all cables along the bottom of the motherboard.
    • Pull the motherboard away from the camcorder.
  7. RCA CC310 Main Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Desolder the two black wires holding the motherboard to the camcorder using a soldering iron.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Oliver Adams
629 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 5-20, Amido Winter 2011 Mitglied von Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 2,690
