Zum Hauptinhalt wechseln
Was du brauchst
  1. RCA Maven Pro 11 Battery Replacement, Cover: Schritt 1, Bild 1 von 2 RCA Maven Pro 11 Battery Replacement, Cover: Schritt 1, Bild 2 von 2
    • Remove all the 8 mm Phillips head screws on the side and back of the device.
  2. RCA Maven Pro 11 Battery Replacement: Schritt 2, Bild 1 von 2 RCA Maven Pro 11 Battery Replacement: Schritt 2, Bild 2 von 2
    • Pry off the cover by sticking a wedge in between the screen and the cover.
    • Be careful with the plastic because it can easily break.
    • Once the cover is partly removed, use your hands to take off the rest of the cover.
  3. RCA Maven Pro 11 Battery Replacement, Battery: Schritt 3, Bild 1 von 2 RCA Maven Pro 11 Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Pull out the pins circled in the picture.
    • These pins can be removed by hand. Just pull on them individually.
  4. RCA Maven Pro 11 Battery Replacement: Schritt 4, Bild 1 von 1
    • Use the opening tools to peel the battery off of the panel.
    • The glue is located in the corners.
    • Do not bend or puncture the battery.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
My husband installed my new battery in my ex's haven pro tablet and when we turned it on it said battery charger 65%. I then turned it back off to co time charging to 100% it when I checked in a few hours, the battery level dropped to 20% and I cannot get it to recharge. It is now completely dead and will not take a charge what should I do?
Carol tyciak - Antwort
My husband installed a new battery into my RCA Maven Pro tablet and when we turned it on, it showed 65% battery life. I then turned it off to continue to charge to 100%. When I checked it in about 4 hours, it was down to 20% and now it is depleted completely and I can't get it to recharge. What should I do now?
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 10
Letzten 30 Tage: 25
Insgesamt: 1,140
