Einleitung
The reset button resets the tablet in the event of a crash. For this guide you will need a Phillips screwdriver.
Was du brauchst
Remove all the 8 mm Phillips head screws on the side and back of the device.
Pry off the cover by sticking a wedge in between the screen and the cover.
Once the cover is partly removed, use your hands to take off the rest of the cover.
Carefully pull up on the power button. There are two pins holding it in.
Remove the power button.
Fast fertig!
Abschluss
