Zum Hauptinhalt wechseln
RCA Pro10 Edition Power/Volume Buttons Replacement
Was du brauchst
  1. RCA Pro10 Edition Power/Volume Buttons Replacement, Speaker: Schritt 1, Bild 1 von 2 RCA Pro10 Edition Power/Volume Buttons Replacement, Speaker: Schritt 1, Bild 2 von 2
    • Using a separating tool, look for a seam in the plastic casing that looks most accessible.
    • Use the prying tool to separate the front and back casing, working your way around the perimeter.
    • Utilize a card tool or a pick to assist in keeping the case separated.
    • To reassemble the device simply align the two casing halves and pinch to snap together or press down on the edges while the device in on a table.
  2. RCA Pro10 Edition Power/Volume Buttons Replacement: Schritt 2, Bild 1 von 1
    • Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
    • Remove the yellow tape securing the speaker to the back casing.
  3. RCA Pro10 Edition Power/Volume Buttons Replacement: Schritt 3, Bild 1 von 2 RCA Pro10 Edition Power/Volume Buttons Replacement: Schritt 3, Bild 2 von 2
    • Use the separating tool to pry the speaker from its surface.
    • Use caution when removing the speaker, you may damage the screen.
    • Cut or desolder the wires to replace or repair the speaker.
  4. RCA Pro10 Edition Power/Volume Buttons Replacement, Camera: Schritt 4, Bild 1 von 3 RCA Pro10 Edition Power/Volume Buttons Replacement, Camera: Schritt 4, Bild 2 von 3 RCA Pro10 Edition Power/Volume Buttons Replacement, Camera: Schritt 4, Bild 3 von 3
    • Using a P00 Phillips screwdriver, remove the three screws securing the black plastic camera housing and remove it.
    • Peel back the beige tape while holding down the camera ribbon cable to prevent tears
  5. RCA Pro10 Edition Power/Volume Buttons Replacement: Schritt 5, Bild 1 von 2 RCA Pro10 Edition Power/Volume Buttons Replacement: Schritt 5, Bild 2 von 2
    • Lift the locking tab that is securing the camera ribbon cable.
    • Slide the ribbon cable out from the connector and remove from casing.
  6. RCA Pro10 Edition Power/Volume Buttons Replacement, Power/Volume Buttons: Schritt 6, Bild 1 von 1
    • Use a P00 Phillips screwdriver to remove the three screws securing the button board.
    • Desolder the contacts on the button board to remove or replace it.
Abschluss
Dayne Russell
401 Reputation
4 Anleitungen geschrieben
Pasco Hernando, Team 1-1, Prince Winter 2015 Mitglied von Pasco Hernando, Team 1-1, Prince Winter 2015
PHSC-PRINCE-W15S1G1
6 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
What is the part number for the Power/Volume Buttons? Where can I purchase one?
EvanSnow - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 993
