Zum Hauptinhalt wechseln
RCA RCR8622 Speaker Replacement
Was du brauchst
  1. RCA RCR8622 Speaker Replacement, Speaker: Schritt 1, Bild 1 von 3 RCA RCR8622 Speaker Replacement, Speaker: Schritt 1, Bild 2 von 3 RCA RCR8622 Speaker Replacement, Speaker: Schritt 1, Bild 3 von 3
    • Remove the casing. Slide the plastic cover with the graphic off the main base. Be careful and hold both sides.
    • Flip the device over and unscrew the five 11 mm screws with a Phillip's #1 screwdriver.
    • A magnetic screwdriver will help you remove the screws from their slots.
  2. RCA RCR8622 Speaker Replacement: Schritt 2, Bild 1 von 3 RCA RCR8622 Speaker Replacement: Schritt 2, Bild 2 von 3 RCA RCR8622 Speaker Replacement: Schritt 2, Bild 3 von 3
    • Pull the top of the device off and look closely at the motherboard. You will see two speakers, one on each side of the device.
    • Grab the tweezers and follow the red and black wires leading from the speaker to the motherboard. They will attach to a white casing. Lift the white plug out with the tweezers to disconnect.
  3. RCA RCR8622 Speaker Replacement: Schritt 3, Bild 1 von 2 RCA RCR8622 Speaker Replacement: Schritt 3, Bild 2 von 2
    • Grab the speaker and pull upward. The Speakers will be loose.
    • Repeat this step with the other speaker.
Abschluss
Josh Excell
449 Reputation
4 Anleitungen geschrieben
IUPUI, Team S6-G5, Baechle Spring 2018 Mitglied von IUPUI, Team S6-G5, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G5
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 302
