Was du brauchst
Remove the two 2.5mm Phillips head screws before attempting to remove the screen from the device.
Run an opening pick around the edge of the screen to loosen it and begin to pry upward.
When the screen comes up like it has in the photo, it should be able to simply be removed from its casing.
The camera is located in the corner of the motherboard, attached by a ribbon cable. Lift up on the black latch that is holding in the ribbon cable and the cable should pop up and out.
Once the cable is removed from the motherboard, the entire camera can simply be removed from the device.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Where can I get the replacement parts (camera and flex cable)
