Einleitung
To avoid damaging the LCD, this guide removes the screen/digitizer from the rear of the device. This replacement requires patience as removing the screen can be tedious. Along with the listed tools, thin, sturdy wedges such as playing cards or guitar picks can greatly simplify and expedite screen removal.
Was du brauchst
Run a spudger tool around the edge of the screen to loosen it and begin to pry upward.
The screen will be able to be removed once you see it pop up like it has in the photo.
Unclip the three ribbon cables from the motherboard by lifting up on their latches (the black portions that the cables feed into) and gently pulling the cables.
To remove the battery, gently pry underneath it and around the edges with your spudger. This will pull it off of the adhesive keeping it on the case.
Remove the three 4 mm Phillip's #00 screws from the motherboard. Then carefully lift off the motherboard from the screen.
To remove the LCD from the screen casing, gently pry it out of the clips that are holding it in place.
With a heat gun, heat along the border of the screen and case to weaken the glue.
Slide a spudger around the edge of the screen. This will disconnect the black edge from the frame.
Starting from one end, use a plastic opening tool to lift the frame away from the screen.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
