Zum Hauptinhalt wechseln
RCA RCT6203W46 Battery Replacement
Was du brauchst
  1. RCA RCT6203W46 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 RCA RCT6203W46 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure the device is off to reduce the chance of an electrical shock. To turn off the device, press and hold the power button.
    • Use a Phillips #00 Screwdriver to unscrew the 4mm (5/32 in.) screws from the back cover of the tablet.
  2. RCA RCT6203W46 Battery Replacement: Schritt 2, Bild 1 von 2 RCA RCT6203W46 Battery Replacement: Schritt 2, Bild 2 von 2
    • Use a spudger to pry the back cover. Start from one edge of the back cover and slide across until the cover is lifted from the tablet body. Repeat for all edges.
  3. RCA RCT6203W46 Battery Replacement: Schritt 3, Bild 1 von 1
    • Open the tablet cover carefully and slowly lengthwise.
    • The keyboard wire ribbon and rear speaker wire should be intact and connected with the back cover.
    • Opening the tablet abruptly may tear or damage cover attachments.
  4. RCA RCT6203W46 Battery Replacement: Schritt 4, Bild 1 von 2 RCA RCT6203W46 Battery Replacement: Schritt 4, Bild 2 von 2
    • Use a spudger to flip up the flap of the ZIF connector that holds the keyboard wire ribbon.
    • Remove the wire ribbon from clamp.
  5. RCA RCT6203W46 Battery Replacement: Schritt 5, Bild 1 von 2 RCA RCT6203W46 Battery Replacement: Schritt 5, Bild 2 von 2
    • Use a soldering iron to melt the solder then remove the red and black wire from the motherboard.
  6. RCA RCT6203W46 Battery Replacement: Schritt 6, Bild 1 von 1
    • Use a spudger to pry and slide underneath the battery to unstick it from the LCD metal plate. It may take a good amount of force to remove.
    • Try to decrease battery deformation by using a spudger rather than prying with your hands.
    • Do not let battery fall back on adhesive, it will stick back onto the LCD metal plate.
    • Be careful to not puncture the battery. The battery may ignite or explode.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
UC Davis, Team 1-2, Oliver Fall 2016 Mitglied von UC Davis, Team 1-2, Oliver Fall 2016
UCD-OLIVER-F16S1G2
5 Mitglieder
4 Anleitungen geschrieben
3 Kommentare
If the battery is bad and the device is plugged in, should it power up or does the battery need to be in good order to power on? Pressing the power button produces a icon outline of a battery with a triangle and asterisk inside it.
John - Antwort
My tablet is doing a strange thing. I powers up then initializes and when it gets to where it says voyager it just stays there indefinately. Occasionally it will complete initalizing then will work for a while then go back to voyager and not work. Is there anything I can do to fix it?
Gerald Couvillion - Antwort
It seems to me that when we got these new they had to charge up for a while before they would “boot” (work) at all. So it stands to reason that if one has a “flaky” battery it might do that. I think that’s what my 7” RCA did when it died. From the 10’ manual, it says,
“Do not wait for the battery to be fully depleted before charging again. Keep the battery charged as needed. If tablet has not been used for a long period of time, the battery might be in over discharge protection mode and may take longer to charge.”
So a flaky battery may put the tablet in the “over discharge protection mode”, meaning it is “cut off” & won’t work.
Gotta ask: where is everyone learning to spell “definitely” as “definately”? Here’s a help to remember: the root word is “finite”, not “finate”.
Good luck with your tablet!
ImJusThinkin -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 24
Insgesamt: 14,585
