Einleitung
In this guide, you will learn how to replace the display screen on your RCA RCT6272W23 tablet.
Was du brauchst
Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
Press the plastic opening tool into the space between the front and back portions of the case.
Run it along the perimeter of the device to unhook the plastic tabs.
Gently pull both sides apart.
Use a soldering iron to remove the soldered connections on the motherboard
Use a philips #00 screwdriver to unscrew the three 4.064mm screws which attach the motherboard to the front of the device.
Use your fingers to pop the three black tabs up to release the flat plastic data transfer cables.
Using a plastic opening tool, pry the battery off of the rest of the body.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
