Einleitung
In this guide, you will learn how to replace the motherboard on a RCA RCT6272W23.
Ersatzteile
Keine Ersatzteile angegeben.
Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
Press the plastic opening tool into the space between the front and back portions of the case.
Run it along the perimeter of the device to unhook the plastic tabs.
Gently pull both sides apart.
Use a soldering iron to remove the soldered connections on the motherboard
Use a philips #00 screwdriver to unscrew the three 4.064mm screws which attach the motherboard to the front of the device.
Use your fingers to pop the three black tabs up to release the flat plastic data transfer cables.
3 weitere Nutzer haben diese Anleitung absolviert.
Ein Kommentar
i need to know everything there is about the motherboard. an tablet. images, info etc
