Einleitung
In this guide, you will learn how to replace the rear camera on your device.
Was du brauchst
Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
Press the plastic opening tool into the space between the front and back portions of the case.
Run it along the perimeter of the device to unhook the plastic tabs.
Gently pull both sides apart.
Use a soldering iron to remove the soldered connections on the motherboard
Use a philips #00 screwdriver to unscrew the three 4.064mm screws which attach the motherboard to the front of the device.
Use your fingers to pop the three black tabs up to release the flat plastic data transfer cables.
Using a spudger, gently pry off the camera from the back of the display
