Einleitung
After noticing your battery life deteriorate or you notice a bulge in the back of the device, it is time to replace the battery. In this guide, you will be removing the following parts:
- 1. Back Cover
- 2. Battery
Was du brauchst
Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
Remove the battery pack by carefully prying the battery back from the front cover. Then remove the wires connecting the battery to the motherboard at the motherboard using the tweezers.
Replace the damaged or malfunctioning battery with the new battery and wires. The new battery must be stuck back into its original place using thermal tape.
The new wires must be soldered back into place on the motherboard at the original location.
For tips on soldering techniques, see this Soldering Guide
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
