Zum Hauptinhalt wechseln
Einleitung
Use this guide to replace the power button on your RCA RCT6378W2 if it is not functioning properly.
Verify that the power button needs to be replaced by ensuring that the device charger is functioning properly, and that the battery has a charge.
Before beginning, make sure the device is powered off.  This may require allowing the battery to drain if power cannot be shut off manually due to the malfunctioning power button.  Make sure the device is not connected to any external power source.
  1. Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver Remove back cover with plastic opening tool to access the power button.
    • Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver
    • Remove back cover with plastic opening tool to access the power button.
  2. Remove and replace the power button using tweezers. Install in reverse order of removal.
    • Remove and replace the power button using tweezers.
    • Install in reverse order of removal.
Abschluss
7 weitere Nutzer haben diese Anleitung absolviert.
mikayla
408 Reputation
2 Anleitungen geschrieben
Clemson, Team 14-4, Shirley Spring 2015 Mitglied von Clemson, Team 14-4, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G4
6 Mitglieder
15 Anleitungen geschrieben
Ein Kommentar
You are the best!!
Thank You, Thank You, Thank You!!
Michael Stephenson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 4
Insgesamt: 3,132
