Zum Hauptinhalt wechseln
Einleitung
Upon using this guide, the user will be able to evaluate and repair problems occurring as a result of a stuck volume button. The guide outlines all tools and steps needed to perform the replacement.
  1. Remove the two 2.4mm x 4mm screws from the bottom of the tablet with a Phillips #00 Screwdriver.
    • Remove the two 2.4mm x 4mm screws from the bottom of the tablet with a Phillips #00 Screwdriver.
  2. Separate the front and back covers using one of the plastic opening tools.
    • Separate the front and back covers using one of the plastic opening tools.
  3. Dislodge the volume button from the upper right corner of the tablet's back cover using the tweezers
    • Dislodge the volume button from the upper right corner of the tablet's back cover using the tweezers
  4. Align and place the new replacement button with positive and negative engravings facing outward into the volume space found in the cover. Align and place the new replacement button with positive and negative engravings facing outward into the volume space found in the cover.
    • Align and place the new replacement button with positive and negative engravings facing outward into the volume space found in the cover.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Matthew Wills
444 Reputation
4 Anleitungen geschrieben
Clemson, Team 14-4, Shirley Spring 2015 Mitglied von Clemson, Team 14-4, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G4
6 Mitglieder
15 Anleitungen geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 192
