Zum Hauptinhalt wechseln
RCA RP3715A Display Replacement
Was du brauchst
  1. RCA RP3715A Display Replacement, Reaching the battery terminal.: Schritt 1, Bild 1 von 2 RCA RP3715A Display Replacement, Reaching the battery terminal.: Schritt 1, Bild 2 von 2
    • Push down on the clip to release pressure. The pull off the plastic cover.
  2. RCA RP3715A Display Replacement, Replacing the battery: Schritt 2, Bild 1 von 1
    • Remove the 9-volt battery from the battery terminal.
  3. RCA RP3715A Display Replacement, Getting inside the device.: Schritt 3, Bild 1 von 1
    • Take out the six screws located on the back of the device.
    • The red screws are 10 mm Phillip's #1. The orange screws are 13 mm Phillips #1.
    • Three screws are located on the back panel. One is located inside the battery carriage.
    • Two screws are located on the on the back panel on the bottom left and right side.
  4. RCA RP3715A Display Replacement, Relieve extension cord tension.: Schritt 4, Bild 1 von 3 RCA RP3715A Display Replacement, Relieve extension cord tension.: Schritt 4, Bild 2 von 3 RCA RP3715A Display Replacement, Relieve extension cord tension.: Schritt 4, Bild 3 von 3
    • Remove the 10 mm Phillip's #1 screw.
    • Then remove the metal reinforcement.
  5. RCA RP3715A Display Replacement: Schritt 5, Bild 1 von 2 RCA RP3715A Display Replacement: Schritt 5, Bild 2 von 2
    • Using flathead screwdriver undo the release tabs.
  6. RCA RP3715A Display Replacement: Schritt 6, Bild 1 von 3 RCA RP3715A Display Replacement: Schritt 6, Bild 2 von 3 RCA RP3715A Display Replacement: Schritt 6, Bild 3 von 3
    • Pry the release tabs with a spudger.
    • Start with back of the device on the topside.
  7. RCA RP3715A Display Replacement: Schritt 7, Bild 1 von 2 RCA RP3715A Display Replacement: Schritt 7, Bild 2 von 2
    • Pry open both tabs to remove the topside of the clock.
  8. RCA RP3715A Display Replacement, Speaker Replacement: Schritt 8, Bild 1 von 1
    • Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
  9. RCA RP3715A Display Replacement, Detaching the front panel: Schritt 9, Bild 1 von 1
    • Remove the two 10 mm Phillip's #1 screws.
  10. RCA RP3715A Display Replacement: Schritt 10, Bild 1 von 1
    • Remove the gray panel from the frame.
  11. RCA RP3715A Display Replacement, Unlatch release tabs: Schritt 11, Bild 1 von 3 RCA RP3715A Display Replacement, Unlatch release tabs: Schritt 11, Bild 2 von 3 RCA RP3715A Display Replacement, Unlatch release tabs: Schritt 11, Bild 3 von 3
    • The two latches located in the picture will help take off the display.
    • Remove the display.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Myles Waiters
370 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 10-5, Brown Fall 2014 Mitglied von USF Tampa, Team 10-5, Brown Fall 2014
USFT-BROWN-F14S10G5
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 324
