Zum Hauptinhalt wechseln
RCA Small Wonders Camcorder CC176 Speaker Replacement
Was du brauchst
  1. RCA Small Wonders Camcorder CC176 Speaker Replacement, Speaker: Schritt 1, Bild 1 von 3 RCA Small Wonders Camcorder CC176 Speaker Replacement, Speaker: Schritt 1, Bild 2 von 3 RCA Small Wonders Camcorder CC176 Speaker Replacement, Speaker: Schritt 1, Bild 3 von 3
    • Remove the small black screws along the edges of the control panel on the top of the device.
    • Pry off the top control panel using the plastic wedge tool.
    • Remove the screw from the front, gray panel located beneath the "Scene Select AE" label.
    • Remove the two small black screws on the top of the front, gray panel of the device, above the red AUTOFOCUS letters.
  2. RCA Small Wonders Camcorder CC176 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Turn the device over and remove the two screws securing the front panel of the device.
    • Remove the screw securing the primary viewfinder, along the front of the camera.
    • Using a flat plastic tool, pry the entire front panel away from the device.
  3. RCA Small Wonders Camcorder CC176 Speaker Replacement: Schritt 3, Bild 1 von 2 RCA Small Wonders Camcorder CC176 Speaker Replacement: Schritt 3, Bild 2 von 2
    • Gently unplug the grey cord, located underneath the panel, disconnecting the speaker from the inner component of the device.
    • Remove the speaker from the device.
Abschluss
Allison Baudoin
401 Reputation
4 Anleitungen geschrieben
James Madison, Team 2-1, Allen Fall 2011 Mitglied von James Madison, Team 2-1, Allen Fall 2011
JMU-ALLEN-F11S2G1
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 939
