Zum Hauptinhalt wechseln
RCA Small Wonders Camcorder CC176 Top Control Panel Replacement
Was du brauchst
  1. RCA Small Wonders Camcorder CC176 Top Control Panel Replacement, Top Control Panel: Schritt 1, Bild 1 von 2 RCA Small Wonders Camcorder CC176 Top Control Panel Replacement, Top Control Panel: Schritt 1, Bild 2 von 2
    • Remove the 5 small black screws along the edges of the control panel at the top of the device.
    • Wedge a small flathead screwdriver around the edges of the panel. Loosen the edges of the panel until it pops away from the device.
    • Locate the blue circuit strip along the underside of the control panel and disconnect it from the inner components of the device.
    • Remove the top control panel from the device after it has been disconnected.
Abschluss
Allison Baudoin
401 Reputation
4 Anleitungen geschrieben
James Madison, Team 2-1, Allen Fall 2011 Mitglied von James Madison, Team 2-1, Allen Fall 2011
JMU-ALLEN-F11S2G1
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 914
