Zum Hauptinhalt wechseln
RCA Small Wonders Camcorder CC176 Viewfinder Replacement
Was du brauchst
  1. RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: Schritt 1, Bild 1 von 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: Schritt 1, Bild 2 von 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: Schritt 1, Bild 3 von 3
    • Remove the 5 screws that secure the control panel (located on the top of the device) by using your small flathead screwdriver.
    • Loosen the panel from the device until you are able to remove it.
  2. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: Schritt 2, Bild 1 von 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: Schritt 2, Bild 2 von 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: Schritt 2, Bild 3 von 3
    • Remove the remaining 21 screws on the camcorder.
    • Begin separating the plastic casing from the inner components of the device.
  3. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: Schritt 3, Bild 1 von 2 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: Schritt 3, Bild 2 von 2
    • Grasping the viewfinder in hand, carefully remove the two screws that secure the mounting device.
    • Locate the gray electrical cord that connects the viewfinder to the inner components of the camera. Gently unplug the gray cord and loosen the viewfinder from the device.
    • Separate the viewfinder from the device and feed the gray cord through the hole in the plastic casing.
Abschluss
Allison Baudoin
401 Reputation
4 Anleitungen geschrieben
James Madison, Team 2-1, Allen Fall 2011 Mitglied von James Madison, Team 2-1, Allen Fall 2011
JMU-ALLEN-F11S2G1
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 1,287
