Einleitung
The RCA ViSYS 25424RE1 phone contains a once piece keypad for dialing phone numbers. This guide can be used to replace the keypad if you're experiencing issues with the buttons. These issues may be caused by using the keypad for a long period of time or by misuse. Using the list of tools and this step-by-step guide, the keypad is easy to replace.
Was du brauchst
Remove the eight 11mm screws found on the bottom side of the base with a Phillips #00 screwdriver.
Unclip the wires that connect the front piece to the circuit board on the back piece.
Remove the nine 11mm screws from the board using a Phillips #00 screwdriver, in order to expose the keyboard pressure sensors.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Lift the rubber keypad.
Use a pair of tweezers to lift the number pad from both ends at the same time.
