Zum Hauptinhalt wechseln
RCA Visys 25212 Handset Battery Replacement
Was du brauchst
  1. RCA Visys 25212 Handset Battery Replacement, Handset Battery: Schritt 1, Bild 1 von 1
    • Place your thumb in the groove on the back of handset. Next, push down with your thumb and then slide the battery cover towards the bottom of the phone to remove the battery cover.
  2. RCA Visys 25212 Handset Battery Replacement: Schritt 2, Bild 1 von 2 RCA Visys 25212 Handset Battery Replacement: Schritt 2, Bild 2 von 2
    • To remove the battery, gently pull up on the white connector located on the left side of the phone.
Abschluss
To reassemble your device, follow these instructions in reverse order. Make sure the battery connector is fully seated in the handset before replacing the back cover.
Sandy South
431 Reputation
4 Anleitungen geschrieben
Pasco Hernando, Team 5-3, Prince Winter 2015 Mitglied von Pasco Hernando, Team 5-3, Prince Winter 2015
PHSC-PRINCE-W15S5G3
6 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 440
