Einleitung
If your RIDGID Belt Sander R2740 doesn’t have power the cause could be from a faulty power cord. This guide will teach you how to replace a power cord on a RIDGID Belt Sander R2740 . For this guide, you will need a screwdriver with a T10, T20 and a Phillips #3 head.
Was du brauchst
Orient the belt sander so that the RIDGID logo is facing you.
Remove the six 19 mm and three 51 mm T20 screws that hold the cover into place.
Remove the cover from the belt sander.
Remove the two 16 mm T10 screws.
Remove the support bracket that holds the power cord into place.
Lift the power cord from the resting grooves.
Rotate the switch so that the lock-on button is facing you.
Loosen the two 8 mm Phillips #3 screws.
Pull the two wires away from the switch.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
