Zum Hauptinhalt wechseln
RIDGID R2740 Motor Replacement
Was du brauchst
  1. RIDGID R2740 Motor Replacement, Motor: Schritt 1, Bild 1 von 1
    • Orient the Ridgid Sander to where the Air Guard logo is facing upwards.
    • Unscrew the outlined screw in the figure with a Torx TR10 screw bit.
    • Remove the guard that is protecting the tread-line.
  2. RIDGID R2740 Motor Replacement: Schritt 2, Bild 1 von 3 RIDGID R2740 Motor Replacement: Schritt 2, Bild 2 von 3 RIDGID R2740 Motor Replacement: Schritt 2, Bild 3 von 3
    • See attached diagram.
    • The guard below the wheels should be able to lift up out of place.
    • Remove the timing belt from the pulleys.
    • Unscrew the three screws with a Phillips #1 screwdriver.
    • Remove the large pulley after removing the screw.
    • Using the Torx TR10 Bit, unscrew the 10 screws which hold the external casing in place.
  3. RIDGID R2740 Motor Replacement: Schritt 3, Bild 1 von 1
    • Remove the plastic housing by lifting it up from the device.
  4. RIDGID R2740 Motor Replacement: Schritt 4, Bild 1 von 1
    • Flip the Ridgid Sander so that the Ridgid logo faces upwards.
    • The Ridgid Logo should be facing upwards.
  5. RIDGID R2740 Motor Replacement: Schritt 5, Bild 1 von 3 RIDGID R2740 Motor Replacement: Schritt 5, Bild 2 von 3 RIDGID R2740 Motor Replacement: Schritt 5, Bild 3 von 3
    • Remove the brush caps from either side using a flathead screwdriver (See attached diagram).
    • Remove the plastic cover with the Ridgid logo.
    • Remove the brush assembly (See attached diagram).
  6. RIDGID R2740 Motor Replacement: Schritt 6, Bild 1 von 2 RIDGID R2740 Motor Replacement: Schritt 6, Bild 2 von 2
    • Now orient the Rigid Sander to the other side that shows the exposed motor.
    • The motor will be able to lift up out of place.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 597
