Zum Hauptinhalt wechseln
RIDGID R32104 Motor Rotor Replacement
Was du brauchst
  1. RIDGID R32104 Motor Rotor Replacement, Motor Brush: Schritt 1, Bild 1 von 2 RIDGID R32104 Motor Rotor Replacement, Motor Brush: Schritt 1, Bild 2 von 2
    • Turn off your saw and unplug before starting.
    • Place down the Worm Drive Saw on a sturdy surface.
    • The motor brush cap is located on the side of the main housing assembly, it can be identified as a large black plastic cap with a slit running down its surface.
  2. RIDGID R32104 Motor Rotor Replacement: Schritt 2, Bild 1 von 2 RIDGID R32104 Motor Rotor Replacement: Schritt 2, Bild 2 von 2
    • Using a flathead screwdriver, remove the motor brush cap from the main housing assembly.
  3. RIDGID R32104 Motor Rotor Replacement: Schritt 3, Bild 1 von 1
    • With the cap removed, the motor brush should now be accessible.
    • Carefully remove the motor brush by sliding it out of the main housing assembly.
  4. RIDGID R32104 Motor Rotor Replacement, Upper Blade Guard Assembly: Schritt 4, Bild 1 von 3 RIDGID R32104 Motor Rotor Replacement, Upper Blade Guard Assembly: Schritt 4, Bild 2 von 3 RIDGID R32104 Motor Rotor Replacement, Upper Blade Guard Assembly: Schritt 4, Bild 3 von 3
    • Maneuver the RIDGID saw, in order to easily remove the upper blade guard assembly.
    • Using the T20 Torx Screwdriver, remove the four 4/10 cm screws that attach to the gear box.
  5. RIDGID R32104 Motor Rotor Replacement: Schritt 5, Bild 1 von 2 RIDGID R32104 Motor Rotor Replacement: Schritt 5, Bild 2 von 2
    • Using the T50 Torx Screwdriver, remove the one 5/10 screw that attach to the gear box.
  6. RIDGID R32104 Motor Rotor Replacement: Schritt 6, Bild 1 von 2 RIDGID R32104 Motor Rotor Replacement: Schritt 6, Bild 2 von 2
    • Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach to the handle of the device.
  7. RIDGID R32104 Motor Rotor Replacement: Schritt 7, Bild 1 von 2 RIDGID R32104 Motor Rotor Replacement: Schritt 7, Bild 2 von 2
    • Maneuver the saw to get to the base plate.
    • Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach the upper blade guard’s base plate to the main housing assembly.
  8. RIDGID R32104 Motor Rotor Replacement, Main Housing Assembly: Schritt 8, Bild 1 von 2 RIDGID R32104 Motor Rotor Replacement, Main Housing Assembly: Schritt 8, Bild 2 von 2
    • Using the T20 Torx Screwdriver, remove the four 10 cm screws that attaches the main housing assembly to the gear box.
  9. RIDGID R32104 Motor Rotor Replacement, Gear Box: Schritt 9, Bild 1 von 2 RIDGID R32104 Motor Rotor Replacement, Gear Box: Schritt 9, Bild 2 von 2
    • Wiggle out the gear box to easily gain access to the motor rotor.
    • Once taken out, the motor rotor is easily accessible.
  10. RIDGID R32104 Motor Rotor Replacement, Motor Rotor: Schritt 10, Bild 1 von 3 RIDGID R32104 Motor Rotor Replacement, Motor Rotor: Schritt 10, Bild 2 von 3 RIDGID R32104 Motor Rotor Replacement, Motor Rotor: Schritt 10, Bild 3 von 3
    • The motor rotor is lodged in between the armature and can be identified as a rod containing a fan blade.
    • Carefully remove the motor rotor from the device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team S5-G1, Julie Spring 2019 Mitglied von UMass Dartmouth, Team S5-G1, Julie Spring 2019
UMASSD-JULIE-S19S5G1
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 41
Insgesamt: 756
