Einleitung
If the blade on your Worn Drive Saw suddenly stops, makes improper cuts, or you experience kickback, the blade is faulty or is misaligned. Use this guide to remove or realign the blade. You just need a H-6 mm Allen Key, in order to remove one type of screw in the replacement process.
Was du brauchst
Place the Worm Drive Saw on a sturdy surface.
The blade is located within its upper blade guard and lower swing guard assembly.
Using a H-6 mm Allen Key, remove the 3/8 - 16 UNC LH screw, washer, and outer blade washer that fixes the blade in place.
Remove the blade by gingerly grabbing towards its center, preventing any injury from occurring.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
