Zum Hauptinhalt wechseln
RIDGID R32104 Saw Blade Replacement
Was du brauchst
  1. RIDGID R32104 Saw Blade Replacement, Saw Blade: Schritt 1, Bild 1 von 1
    • Turn off your saw and unplug before starting.
    • The RIDGID R32104 Saw did not come with a blade, so paper was used to mime the actions needed.
    • Place the Worm Drive Saw on a sturdy surface.
    • The blade is located within its upper blade guard and lower swing guard assembly.
  2. RIDGID R32104 Saw Blade Replacement: Schritt 2, Bild 1 von 2 RIDGID R32104 Saw Blade Replacement: Schritt 2, Bild 2 von 2
    • Using a H-6 mm Allen Key, remove the 3/8 - 16 UNC LH screw, washer, and outer blade washer that fixes the blade in place.
    • In order to unscrew this, you must turn the screw clockwise to loosen it.
  3. RIDGID R32104 Saw Blade Replacement: Schritt 3, Bild 1 von 1
    • Adjust the lower swing guard to properly grab the blade.
  4. RIDGID R32104 Saw Blade Replacement: Schritt 4, Bild 1 von 1
    • Remove the blade by gingerly grabbing towards its center, preventing any injury from occurring.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team S5-G1, Julie Spring 2019 Mitglied von UMass Dartmouth, Team S5-G1, Julie Spring 2019
UMASSD-JULIE-S19S5G1
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 27
Letzte 30 Tage: 78
Insgesamt: 1,718
