Einleitung
Use for a diagnosed wiring problem.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the backplate.
Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
Remove the drill handle.
Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
Remove the gear casing from the body.
Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
Use a multimeter set above 18V DC to check electrical connections where wires meet drill, switch, or battery terminal.
Look for corrosion or burnt wires.
If there are any bad connections or if there is visible damage, replace damaged wire and solder.
Ein weiterer Nutzer hat diese Anleitung absolviert.
