Einleitung
If your drill does not turn on with a fully charged battery, the motor of your drill might be damaged. This guide will provide guidance to the process of replacing a defective motor in a RIDGID R860052.
Was du brauchst
Use a T10 Torx screwdriver to remove the ten screws on the information label side of the drill.
Twist the chuck and motor in the opposite direction and gently pull them apart.
Desolder the black and red wires from the motor.
Replace motor and resolder the black and red wires back onto the motor.
