Einleitung
Follow this comprehensive guide to repair a broken headband for your RK5 Plus Virtual Reality Glasses Case. The headband is an important component of your VR headset as it keeps the device securely on your head. Due to frequent use and the pressure exerted on it, the headband of this VR headset may become overstretched, snap or rip. This guide will show you how to replace the headband of your RK5 Plus Virtual Reality Glasses Case.
Was du brauchst
Place the headset right side up and facing you on a flat surface.
Gently detach the velcro straps from the top, left, and right sides of the headset and set them aside.
Remove the white headband adjustment part and carefully pull it off of the three straps.
To access the straps that need to be replaced, remove the padding around the visual lenses of the headset.
To do this, use your hands to detach the plastic frame between the padding and the lenses.
Unhook the old straps from the sides of the headset.
Reattach the top band into the top hook of the headset.
Take the other sides of the velcro straps and hook them into the white headband adjustment part.
Check that the straps are properly aligned and securely attached to the headband adjustment part.
You have successfully replaced your damaged headbands for the RK5 Plus VR headset!
