Zum Hauptinhalt wechseln
RK5 PLUS VR Headset Headband Replacement
Was du brauchst
  1. RK5 PLUS VR Headset Headband Replacement, Headband: Schritt 1, Bild 1 von 3 RK5 PLUS VR Headset Headband Replacement, Headband: Schritt 1, Bild 2 von 3 RK5 PLUS VR Headset Headband Replacement, Headband: Schritt 1, Bild 3 von 3
    • Place the headset right side up and facing you on a flat surface.
    • Gently detach the velcro straps from the top, left, and right sides of the headset and set them aside.
  2. RK5 PLUS VR Headset Headband Replacement: Schritt 2, Bild 1 von 1
    • Remove the white headband adjustment part and carefully pull it off of the three straps.
  3. RK5 PLUS VR Headset Headband Replacement: Schritt 3, Bild 1 von 3 RK5 PLUS VR Headset Headband Replacement: Schritt 3, Bild 2 von 3 RK5 PLUS VR Headset Headband Replacement: Schritt 3, Bild 3 von 3
    • To access the straps that need to be replaced, remove the padding around the visual lenses of the headset.
    • To do this, use your hands to detach the plastic frame between the padding and the lenses.
    • If you need help getting started, use a spudger or opening tool and undo the clips holding the plastic frame.
    • Unhook the old straps from the sides of the headset.
  4. RK5 PLUS VR Headset Headband Replacement: Schritt 4, Bild 1 von 3 RK5 PLUS VR Headset Headband Replacement: Schritt 4, Bild 2 von 3 RK5 PLUS VR Headset Headband Replacement: Schritt 4, Bild 3 von 3
    • Reattach the new velcro straps to each of the white hooks.
    • Make sure the straps are securely attached to the hooks before moving on to the next step.
  5. RK5 PLUS VR Headset Headband Replacement: Schritt 5, Bild 1 von 2 RK5 PLUS VR Headset Headband Replacement: Schritt 5, Bild 2 von 2
    • Reattach the plastic frame with the padded back onto the headset.
    • Make sure the padding is properly aligned and clicked into place.
  6. RK5 PLUS VR Headset Headband Replacement: Schritt 6, Bild 1 von 3 RK5 PLUS VR Headset Headband Replacement: Schritt 6, Bild 2 von 3 RK5 PLUS VR Headset Headband Replacement: Schritt 6, Bild 3 von 3
    • Reattach the top band into the top hook of the headset.
    • Take the other sides of the velcro straps and hook them into the white headband adjustment part.
    • Check that the straps are properly aligned and securely attached to the headband adjustment part.
  7. RK5 PLUS VR Headset Headband Replacement: Schritt 7, Bild 1 von 1
    • You have successfully replaced your damaged headbands for the RK5 Plus VR headset!
Abschluss
Faraaz Abdul
145 Reputation
1 Anleitung geschrieben
York University, Team M-1, Allen Winter 2023 Mitglied von York University, Team M-1, Allen Winter 2023
YORK-ALLEN-W23SMG1
1 Mitglied
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 397
