Zum Hauptinhalt wechseln
ROG Strix G15 G512LI M.2 SSD Replacement
Was du brauchst
  1. ROG Strix G15 G512LI M.2 SSD Replacement, Removing The Cover: Schritt 1, Bild 1 von 1
    • Remove the screws from the compartment cover, As show in the diagram, unscrew the screws labeled "A" first. before unscrewing "B", Don't remove screw "B" from the cover.
  2. ROG Strix G15 G512LI M.2 SSD Replacement: Schritt 2, Bild 1 von 1
    • Remove the panel, but be careful as there are 2 cables linking the RGB light bar to the motherboard, carefully and gently detach them from the motherboard and lift the panel.
  3. ROG Strix G15 G512LI M.2 SSD Replacement, Installing The SSD: Schritt 3, Bild 1 von 2 ROG Strix G15 G512LI M.2 SSD Replacement, Installing The SSD: Schritt 3, Bild 2 von 2
    • Locate the M.2 SSD slots, the First and Third slots both support SATA and PCIe NVMe M.2 SSDs, and the second M.2 Slot only supports PCIe NVMe SSDs
    • Next, Insert the NVMe SSD, and screw the SSD into place with the retaining screws
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
June
617 Reputation
3 Anleitungen geschrieben
2 Kommentare zur Anleitung
how to fix the light bar i have one side wont light on
fethallah - Antwort Teilen
are the m.2 nvme slot PCIe 3.0x4 and are they all the same speed or type?
Yousef Suwaidan - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 30
Letzte 30 Tage: 90
Insgesamt: 9,268
