Zum Hauptinhalt wechseln
ROYALAXE R68 TKL Key Switches Replacement
Was du brauchst
  1. ROYALAXE R68 TKL Key Switches Replacement, Key Switches: Schritt 1, Bild 1 von 2 ROYALAXE R68 TKL Key Switches Replacement, Key Switches: Schritt 1, Bild 2 von 2
    • Unplug the keyboard from its power source.
  2. ROYALAXE R68 TKL Key Switches Replacement: Schritt 2, Bild 1 von 1
    • Remove all keycaps with the keycap puller.
    • You can line up the keycaps in order or take a picture of your keyboard to make it easier to put them back on at the end.
  3. ROYALAXE R68 TKL Key Switches Replacement: Schritt 3, Bild 1 von 2 ROYALAXE R68 TKL Key Switches Replacement: Schritt 3, Bild 2 von 2
    • Clean the keyboard using a compressed air duster and a small brush or cotton swab.
    • You can also clean your keycaps by soaking them in a bowl with water and soap for about 30 minutes.
  4. ROYALAXE R68 TKL Key Switches Replacement: Schritt 4, Bild 1 von 2 ROYALAXE R68 TKL Key Switches Replacement: Schritt 4, Bild 2 von 2
    • Remove the switches with the switch puller.
    • Make sure to clamp on the switch vertically instead of horizontally. Then gently pull it out.
    • Taking out the switch by pulling horizontally could damage the switch.
  5. ROYALAXE R68 TKL Key Switches Replacement: Schritt 5, Bild 1 von 3 ROYALAXE R68 TKL Key Switches Replacement: Schritt 5, Bild 2 von 3 ROYALAXE R68 TKL Key Switches Replacement: Schritt 5, Bild 3 von 3
    • Make sure the copper part of the switch faces you when you try to insert the switch.
    • Insert the key switch as straight as possible and press down gently until you hear a click.
    • If you fail to line it up, it will bend the copper part under the switch. This will permanently damage the switch.
  6. ROYALAXE R68 TKL Key Switches Replacement: Schritt 6, Bild 1 von 2 ROYALAXE R68 TKL Key Switches Replacement: Schritt 6, Bild 2 von 2
    • Place keycaps in their respective position.
    • Make sure all keys are operating well.
    • Enjoy your new switches!
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Angie
163 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 4-5, Kershman Fall 2023 Mitglied von CSU Los Angeles, Team 4-5, Kershman Fall 2023
CSULA-KERSHMAN-F23S4G5
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 163
