Einleitung
This guide will assist with the switch replacement for the ROYALAXE R68 TKL Mechanical Keyboard.
This keyboard has a Hot-swappable design. This enables super convenient pullout and pop-in of the switches. Replacing the key switches does not require significant prior knowledge; you can do this with the tools provided with this keyboard. Therefore, it is rated as "easy."
Was du brauchst
Clean the keyboard using a compressed air duster and a small brush or cotton swab.
Remove the switches with the switch puller.
Make sure to clamp on the switch vertically instead of horizontally. Then gently pull it out.
Insert the key switch as straight as possible and press down gently until you hear a click.
Place keycaps in their respective position.
Make sure all keys are operating well.
Enjoy your new switches!
Eine weitere Person hat diese Anleitung absolviert.
