Zum Hauptinhalt wechseln
RYDIS H68 Pro Side Brush Motor Replacement
Was du brauchst
  1. RYDIS H68 Pro Side Brush Motor Replacement, Battery: Schritt 1, Bild 1 von 2 RYDIS H68 Pro Side Brush Motor Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the vacuum over so that the wheels are facing you.
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
  2. RYDIS H68 Pro Side Brush Motor Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery cover up to reveal the battery.
    • Remove the battery.
  3. RYDIS H68 Pro Side Brush Motor Replacement, Bumper: Schritt 3, Bild 1 von 3 RYDIS H68 Pro Side Brush Motor Replacement, Bumper: Schritt 3, Bild 2 von 3 RYDIS H68 Pro Side Brush Motor Replacement, Bumper: Schritt 3, Bild 3 von 3
    • Remove the eight 10 mm Phillips #1 screws.
  4. RYDIS H68 Pro Side Brush Motor Replacement: Schritt 4, Bild 1 von 3 RYDIS H68 Pro Side Brush Motor Replacement: Schritt 4, Bild 2 von 3 RYDIS H68 Pro Side Brush Motor Replacement: Schritt 4, Bild 3 von 3
    • Hold the front bumper and pull it off.
    • It requires a lot of force to pull the bumper off.
  5. RYDIS H68 Pro Side Brush Motor Replacement: Schritt 5, Bild 1 von 3 RYDIS H68 Pro Side Brush Motor Replacement: Schritt 5, Bild 2 von 3 RYDIS H68 Pro Side Brush Motor Replacement: Schritt 5, Bild 3 von 3
    • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
  6. RYDIS H68 Pro Side Brush Motor Replacement, Side Brush Motor: Schritt 6, Bild 1 von 1
    • Begin by unscrewing the 2 10mm screws using a Phillips #1 screwdriver.
    • Unlatch the latches indicated. It can be easily done with your finger.
    • Once unsecured, the covering for the sensors can easily be removed allowing access to the sensors.
    • The reason for these first few steps is to avoid damaging the signal wires for the sensor.
  7. RYDIS H68 Pro Side Brush Motor Replacement: Schritt 7, Bild 1 von 1
    • This step just shows you how everything looks after the previous steps were completed.
    • There are sensors on both the left and right side. This can be done for either side.
  8. RYDIS H68 Pro Side Brush Motor Replacement: Schritt 8, Bild 1 von 1
    • Unscrew the five 10mm screws using a Phillips #1 screwdriver.
  9. RYDIS H68 Pro Side Brush Motor Replacement: Schritt 9, Bild 1 von 1
    • The side brush motor can now be removed by lifting it up.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USFT-Lacy-S17S005G2 Mitglied von USFT-Lacy-S17S005G2
Local Repair Groups
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 589
