Zum Hauptinhalt wechseln
RYOBI 404Y Leaf Blower Handle Replacement
Was du brauchst
    1. RYOBI 404Y Leaf Blower Handle Replacement, Handle: Schritt 1, Bild 1 von 1
      • Pretty easy fix, can be done in 10-15 minutes.
      Frag FixBot
      Kommentar hinzufügen
    2. RYOBI 404Y Leaf Blower Handle Replacement: Schritt 2, Bild 1 von 1
      • This style of handle can become cracked at the base. In this case it was broken almost completely through and very weak, but it can be replaced. This
      Frag FixBot
    3. RYOBI 404Y Leaf Blower Handle Replacement: Schritt 3, Bild 1 von 1
      • The replacement handle is listed as "HOMELITE RYOBI 311220001 Genuine Handle Assembly" and can be found at a couple of online parts sources. Currently (8/2021) available at Amazon, eReplacement parts & Parts Warehouse.
      Frag FixBot
    4. RYOBI 404Y Leaf Blower Handle Replacement: Schritt 4, Bild 1 von 1
      • Handle housing is a simple clamshell design.
      Frag FixBot
    5. RYOBI 404Y Leaf Blower Handle Replacement: Schritt 5, Bild 1 von 1
      • I was able to open this without the use of prying tools.
      Frag FixBot
    6. RYOBI 404Y Leaf Blower Handle Replacement: Schritt 6, Bild 1 von 1
      • This view shows you the 3 alignment tabs. (see arrows on blue tape in picture) The handle slides onto these tabs. There will be no other clips or tabs.
      Frag FixBot
    7. RYOBI 404Y Leaf Blower Handle Replacement: Schritt 7, Bild 1 von 1
      • Wire routing is also simple. Wires are pushed into grooves in the handle. Remove wire harness and switch with a gentle tug. Reassemble in reverse order. You will notice that the screw positions have a male/female fit helping with alignment.
      Frag FixBot
Abschluss
Reinstall wire harness into handle.
Slide handle onto the 3 base tabs.
Reinstall 10 Torx screws.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 49
Insgesamt: 3,128
