Was du brauchst
To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
Remove the four 1.8 cm screws from the lower and mid section of the body with the Torx T20 screwdriver.
Remove the 3.7 cm screws from the upper section of the body, with the same screwdriver.
Lift up main trigger and spring together.
By lifting this trigger and spring out of the handle, you will pull double duty by lifting the black switch box off of its two support posts.
Slide the trigger off of the black switch box.
Flip the grinder over and lift off the second half of the body.
Now you can replace your damaged handles with a new pair.
2 weitere Personen haben diese Anleitung absolviert.
