Einleitung
If your springs become damaged or weak from extended use, it's wise to replace them to ensure proper function. These springs may be under compression/ tension, so be wary when removing/ replacing these parts.
Was du brauchst
To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
Remove the four 1.8 cm screws from the lower and midsection of the body with a T20-20 Torque screwdriver.
Remove the 3.7 cm screws from the upper section of the body, with the same screwdriver
Remove the safety trigger along with the spring.
To remove the spring, pull it gently off the bottom of the trigger.
