Einleitung
Use this guide to replace the old spring of the case lid in your Radica Lighted Poker device.
The spring is the central piece that reacts with the lid closing and opening to play with your portable poker. An old spring, due to stress or weather effects, may cause it to be worn out or even rust.
If the spring is in good condition and opens and closes the lid, this is not the correct guide for you.
Was du brauchst
Open the device slowly without breaking or tearing the wires.
Remove the three black 7 mm self-sealing screws using a Phillips #00 screwdriver.
Gently remove both the button and hook piece.
Remove the damaged or old spring with a new 10 mm long and 8 mm to 3 mm radius spring.
