Zum Hauptinhalt wechseln
Rain-X Chipped Windshield Repair
Was du brauchst
  1. Rain-X Chipped Windshield Repair, Rain-X Chipped Windshield Repair: Schritt 1, Bild 1 von 3 Rain-X Chipped Windshield Repair, Rain-X Chipped Windshield Repair: Schritt 1, Bild 2 von 3 Rain-X Chipped Windshield Repair, Rain-X Chipped Windshield Repair: Schritt 1, Bild 3 von 3
    • To remove excess glass, scrape over the surface of the chip with the included razor blade.
  2. Rain-X Chipped Windshield Repair: Schritt 2, Bild 1 von 2 Rain-X Chipped Windshield Repair: Schritt 2, Bild 2 von 2
    • Attach the Rain-X applicator base to the windshield, with the center of the base directly above the chip.
  3. Rain-X Chipped Windshield Repair: Schritt 3, Bild 1 von 2 Rain-X Chipped Windshield Repair: Schritt 3, Bild 2 von 2
    • Cut the tip of the repair resin bottle using the razor blade.
  4. Rain-X Chipped Windshield Repair: Schritt 4, Bild 1 von 3 Rain-X Chipped Windshield Repair: Schritt 4, Bild 2 von 3 Rain-X Chipped Windshield Repair: Schritt 4, Bild 3 von 3
    • To attach resin chamber, screw the chamber into the center ring of the applicator base.
  5. Rain-X Chipped Windshield Repair: Schritt 5, Bild 1 von 1
    • Screw the resin chamber clockwise until it is in contact with the windshield.
  6. Rain-X Chipped Windshield Repair: Schritt 6, Bild 1 von 3 Rain-X Chipped Windshield Repair: Schritt 6, Bild 2 von 3 Rain-X Chipped Windshield Repair: Schritt 6, Bild 3 von 3
    • Apply 3-6 drops of resin from the resin repair bottle into the resin chamber.
  7. Rain-X Chipped Windshield Repair: Schritt 7, Bild 1 von 3 Rain-X Chipped Windshield Repair: Schritt 7, Bild 2 von 3 Rain-X Chipped Windshield Repair: Schritt 7, Bild 3 von 3
    • To add the pressure driver, screw the driver clockwise into the resin chamber.
    • Make sure to tighten almost all the way.
    • Make sure the pressure driver is in contact with the windshield.
  8. Rain-X Chipped Windshield Repair: Schritt 8, Bild 1 von 1
    • Set timer for 4-6 minutes - Let the adhesive absorb into the chip for 4-6 minutes.
    • To determine if the repair resin has absorbed properly, look at the glass from a 45 degree angle.
    • After the 4-6 minutes end, unscrew the pressure driver, turning it counter clockwise. Remove it to release any trapped air.
  9. Rain-X Chipped Windshield Repair: Schritt 9, Bild 1 von 2 Rain-X Chipped Windshield Repair: Schritt 9, Bild 2 von 2
    • Reinsert pressure driver by twisting clockwise.
    • This will discard any air remaining in the chip.
  10. Rain-X Chipped Windshield Repair: Schritt 10, Bild 1 von 1
    • To check for remaining damage, look for a dark color to appear.
  11. Rain-X Chipped Windshield Repair: Schritt 11, Bild 1 von 1
    • Leave to cure for 5-10 minutes.
  12. Rain-X Chipped Windshield Repair: Schritt 12, Bild 1 von 2 Rain-X Chipped Windshield Repair: Schritt 12, Bild 2 von 2
    • Once finished curing, remove the resin chamber and the pressure driver by screwing counter clockwise.
  13. Rain-X Chipped Windshield Repair: Schritt 13, Bild 1 von 2 Rain-X Chipped Windshield Repair: Schritt 13, Bild 2 von 2
    • Remove the applicator by using the tabs on the suction cups.
  14. Rain-X Chipped Windshield Repair: Schritt 14, Bild 1 von 2 Rain-X Chipped Windshield Repair: Schritt 14, Bild 2 von 2
    • Clean off any excess adhesive from the windshield.
  15. Rain-X Chipped Windshield Repair: Schritt 15, Bild 1 von 2 Rain-X Chipped Windshield Repair: Schritt 15, Bild 2 von 2
    • Cover the chip gently with a curing strip.
  16. Rain-X Chipped Windshield Repair: Schritt 16, Bild 1 von 1
    • Move the car into direct sunlight and leave for 4-6 hours.
    • Remove the curing strip and enjoy.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
UC Davis, Team S1-G8, Bender Fall 2018 Mitglied von UC Davis, Team S1-G8, Bender Fall 2018
UCD-BENDER-F18S1G8
3 Mitglieder
1 Anleitung geschrieben
Ein Kommentar
If you do not have a sunny day, what is the best UV wavelength in nm, watts, and length of time to fully cure the resin.
Thanks much!
AZRic - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 20
Letzte 30 Tage: 83
Insgesamt: 4,708
