Zum Hauptinhalt wechseln
Raleigh M20 Bicycle Rear Rack Replacement
Was du brauchst
  1. Raleigh M20 Bicycle Rear Rack Replacement, Bicycle Rear Rack: Schritt 1, Bild 1 von 2 Raleigh M20 Bicycle Rear Rack Replacement, Bicycle Rear Rack: Schritt 1, Bild 2 von 2
    • Make sure that the bike is upright and stable.
    • With both hands, place the rear rack on the rear wheel of the bike. Take note of where the rear rack will attach on the bike.
    • Make sure that the rear rack is fitted on the bike.
  2. Raleigh M20 Bicycle Rear Rack Replacement: Schritt 2, Bild 1 von 3 Raleigh M20 Bicycle Rear Rack Replacement: Schritt 2, Bild 2 von 3 Raleigh M20 Bicycle Rear Rack Replacement: Schritt 2, Bild 3 von 3
    • Place a screw to attach the rear rack to the frame of the tire.
    • Tighten the screw with a philips screwdriver by turning it in a clockwise direction.
    • Repeat the steps above on the other side of the bike.
  3. Raleigh M20 Bicycle Rear Rack Replacement: Schritt 3, Bild 1 von 3 Raleigh M20 Bicycle Rear Rack Replacement: Schritt 3, Bild 2 von 3 Raleigh M20 Bicycle Rear Rack Replacement: Schritt 3, Bild 3 von 3
    • Place the metal holder to be even with the bar sticking out of the rear rack.
    • Line up the holes. Place a bolt to attach them together.
    • Use a philips screwdriver to tighten the bolts.
    • Do this for both sides.
  4. Raleigh M20 Bicycle Rear Rack Replacement: Schritt 4, Bild 1 von 2 Raleigh M20 Bicycle Rear Rack Replacement: Schritt 4, Bild 2 von 2
    • Make sure that the rear rack is even. If it is not, redo the previous step.
    • Locate the screws on top of the rear rack. Tighten the screws using a philips screwdriver.
    • Once the screws are tightened, you are done.
Abschluss
To detach the rear rack, follow the instructions of this guide in the reverse order.
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 7-49, Forte Fall 2012 Mitglied von Cal Poly, Team 7-49, Forte Fall 2012
CPSU-FORTE-F12S7G49
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 3,016
