Was du brauchst
Using a 3/8" Allen wrench, loosen the nuts that hold the brake controls and gear shifters.
Place an Allen wrench (size doesn't matter) under the bike grip.
Twist the grip back and forth while pulling on the Allen wrench to remove the grip.
Loosen the central nut on the faceplate that connects the bars to the steering column. If the bars are secured by a faceplate with a detachable top, loosen the nuts on the faceplate and remove.
Lift the handlebars from the bike frame.
To reinstall the handlebars, complete these steps in reverse order. If there is a problem with the alignment, return to the handlebar repair guide and repeat step 4.
