Zum Hauptinhalt wechseln
Raleigh M20 Handlebars Replacement
Was du brauchst
  1. Raleigh M20 Handlebars Replacement, Handlebars: Schritt 1, Bild 1 von 2 Raleigh M20 Handlebars Replacement, Handlebars: Schritt 1, Bild 2 von 2
    • Strip all the accessories from your old handlebars. (reflectors, mirrors, etc...)
    • Using a 3/8" Allen wrench, loosen the nuts that hold the brake controls and gear shifters.
  2. Raleigh M20 Handlebars Replacement: Schritt 2, Bild 1 von 3 Raleigh M20 Handlebars Replacement: Schritt 2, Bild 2 von 3 Raleigh M20 Handlebars Replacement: Schritt 2, Bild 3 von 3
    • Place an Allen wrench (size doesn't matter) under the bike grip.
    • Twist the grip back and forth while pulling on the Allen wrench to remove the grip.
  3. Raleigh M20 Handlebars Replacement: Schritt 3, Bild 1 von 2 Raleigh M20 Handlebars Replacement: Schritt 3, Bild 2 von 2
    • Slide off the gear shifters.
    • Slide off the brake controls.
  4. Raleigh M20 Handlebars Replacement: Schritt 4, Bild 1 von 3 Raleigh M20 Handlebars Replacement: Schritt 4, Bild 2 von 3 Raleigh M20 Handlebars Replacement: Schritt 4, Bild 3 von 3
    • Loosen the central nut on the faceplate that connects the bars to the steering column. If the bars are secured by a faceplate with a detachable top, loosen the nuts on the faceplate and remove.
    • Lift the handlebars from the bike frame.
    • Move the bars until they're in the correct position for your stance. Tighten the faceplate nuts with a 3/8" Allen wrench to firmly secure the handlebars in place.
    • Sit on the bike and make final adjustments to the positioning of the brakes and gears.
Abschluss
To reinstall the handlebars, complete these steps in reverse order. If there is a problem with the alignment, return to the handlebar repair guide and repeat step 4.
Jon Ribera
72 Reputation
1 Anleitung geschrieben
Cal Poly, Team 7-49, Forte Fall 2012 Mitglied von Cal Poly, Team 7-49, Forte Fall 2012
CPSU-FORTE-F12S7G49
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 2,140
