Einleitung
This simple guide will show you how to change the cable in a Rapoo N1600 mouse. This guide does require disassembling, so try not to lose any parts! One thing to note in Step 2 is that the screw may be difficult to remove, so there's a chance you might have to pry it open. Don't worry; you won't need to screw it back since the mouse runs smoothly without the screw.
Was du brauchst
Use the iFixit opening tool to lift the cable connector plug slowly.
Using two fingers, slowly wiggle the connector plug out.
Place your index finger under the motherboard and lift your index finger so the motherboard pops up.
Remove the old mouse cable.
Place the matching cross from the new mouse cable on the cross outline.
Keep the cable away from the scroll wheel area. Make sure the cable stays to the side.
Make sure the mouse sensor stays in place. If it falls out, set it back in place.
To replace the motherboard, match the circle from the motherboard and mouse and press down.
Add the mouse cable plug to the socket. Press down so it connects.
Slide an iFixit opening pick between the top shell and middle slowly until the end. Do this for the other side as well.
Match the middle part of the mouse with the bottom and slide it from top to bottom.
Once the middle part is attached, add the top shell of the mouse. Follow the pattern of the holes as they will help you.
Eine weitere Person hat diese Anleitung absolviert.
