Zum Hauptinhalt wechseln
Razer BlackWidow Chroma Key Replacement
Was du brauchst
  1. Razer BlackWidow Chroma Key Replacement, Key: Schritt 1, Bild 1 von 1
    • If the problematic key is still attached, place the edge of the medium blue pry tool under the key. Then gently pry up until key is detached.
  2. Razer BlackWidow Chroma Key Replacement: Schritt 2, Bild 1 von 1
    • Some larger keys may also be held in by two small metal hooks. To separate them gently slide the key left to separate right hook, then to the right to separate the left hook. Be careful not to break the mounting holes on the key itself.
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
UW Tacoma, Team 2-6, Rose Winter 2017 Mitglied von UW Tacoma, Team 2-6, Rose Winter 2017
UWT-ROSE-W17S2G6
3 Mitglieder
4 Anleitungen geschrieben
3 Kommentare
This has absolutely nothing to do with fixing a stuck key. Useless information.
Kyle - Antwort
99% of steps to replace a key is missing. What a joke.
Jacinto - Antwort
please change the name to “keycap” I don’t see this as useless but, misleading.
Shaun Conklin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 56
Insgesamt: 13,338
