Zum Hauptinhalt wechseln
Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement
Was du brauchst
  1. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement, USB Port Board: Schritt 1, Bild 1 von 3 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement, USB Port Board: Schritt 1, Bild 2 von 3 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement, USB Port Board: Schritt 1, Bild 3 von 3
    • Remove the four plastic covers and rubber feet from all four corners of the keyboard.
    • Remove the four screws.
    • Carefully pry around the bottom end of the keyboard and work your way around keyboard to un-clip the face.
  2. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: Schritt 2, Bild 1 von 2 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: Schritt 2, Bild 2 von 2
    • Turn the keyboard face up.
    • Remove the four screws which attach the keys.
    • Note the orientation of the white plastic cover relative to the LED at the bottom of the board.
  3. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: Schritt 3, Bild 1 von 1
    • Locate the USB at the top of the device.
    • Remove the two screws attaching the USB.
  4. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: Schritt 4, Bild 1 von 2 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: Schritt 4, Bild 2 von 2
    • Unplug the cable connecting to the USB board.
    • Plug the new USB board into the slot.
    • Replace the screws in the USB board.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
4 Kommentare
hi, where do i get the new board from? thanks!
Doge The Best - Antwort
You can easily find it on Ebay
Here's a link, i had the same issue
https://www.ebay.com/itm/272275162673htt...
iixroyal owlroyal -
Hey, you can easily Google the details on the USB board bottom left
I had the same issue
iixroyal owlroyal - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 10
Letzte 30 Tage: 31
Insgesamt: 5,027
