Einleitung
This guide explains how to replace the USB port in the Razer Blackwidow Tournament Edition keyboard.
Was du brauchst
Remove the four plastic covers and rubber feet from all four corners of the keyboard.
Remove the four screws.
Carefully pry around the bottom end of the keyboard and work your way around keyboard to un-clip the face.
Locate the USB at the top of the device.
Remove the two screws attaching the USB.
Unplug the cable connecting to the USB board.
Plug the new USB board into the slot.
Replace the screws in the USB board.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
4 Kommentare
hi, where do i get the new board from? thanks!
You can easily find it on Ebay
Here's a link, i had the same issue
I need one too
Hey, you can easily Google the details on the USB board bottom left
I had the same issue
