Einleitung
This guide is to help teach anyone in need of replacing the battery in their Razer Blade 2014 laptop, model number RZ09-0195. For safety before the repair process, make sure the laptop is in a powered off state before you begin.
Laptop batteries can deteriorate after a certain number of years, so replacing the battery is actually more cost-effective and less complicated than purchasing a new computer.
Aging batteries can cause problems ranging from a noticeable decrease in storage capacity to a bulging of the battery in the case of a heavier battery.
Note: Make sure to place the laptop on a clean and dust-free platform before starting. Keep hands dry during the operation. The tweezers used should not be fully metallic tweezers to prevent the occurrence of conduction current; computer-specific tweezers are needed.
Was du brauchst
Use a P2 Pentalobe screwdriver to remove the ten screws on the laptop's backplate.
Use tweezers to detach the silver connector that is attached to the battery with an orange cable.
Use tweezers to gently lift the retaining flap upwards.
Use tweezers to gently pull the white cable outward.
