Zum Hauptinhalt wechseln
Razer Blade RZ09-0130 2015 Display Replacement
Was du brauchst
  1. Razer Blade RZ09-0130 2015 Display Replacement, Back Panel: Schritt 1, Bild 1 von 2 Razer Blade RZ09-0130 2015 Display Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Display Replacement: Schritt 2, Bild 1 von 2 Razer Blade RZ09-0130 2015 Display Replacement: Schritt 2, Bild 2 von 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Display Replacement, Display: Schritt 3, Bild 1 von 1
    • Remove the two 5mm Phillips #00 screws.
  4. Razer Blade RZ09-0130 2015 Display Replacement: Schritt 4, Bild 1 von 1
    • Remove the plastic panel.
  5. Razer Blade RZ09-0130 2015 Display Replacement: Schritt 5, Bild 1 von 1
    • Remove one 3mm Phillips #00 screw from the metal plate.
  6. Razer Blade RZ09-0130 2015 Display Replacement: Schritt 6, Bild 1 von 1
    • Repeat the previous three steps on the opposing side.
  7. Razer Blade RZ09-0130 2015 Display Replacement: Schritt 7, Bild 1 von 1
    • Gently open the device with your hands and separate the display from the keyboard.
    • The device will make a popping or cracking sound when the two pieces separate. This is normal.
Abschluss
Ben Haering
121 Reputation
1 Anleitung geschrieben
Cal Poly, Team S18-G1, White Winter 2020 Mitglied von Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 14
Insgesamt: 756
