Einleitung
If the display on your Razer Blade RZ09-0130 2015 laptop is physically damaged, this guide will demonstrate how you can properly replace the display. It should be noted the display is both the screen and casing behind the screen. If the casing is damaged, this replacement will also ensure a new screen. Be sure there is noticeable disfiguration on the screen (cracks, scratches, etc.) before applying this procedure, otherwise the display malfunction can be traced back to a software related problem.
Was du brauchst
Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
Gently open the device with your hands and separate the display from the keyboard.
